After importing or creating your own terrain, you may want to add new entities to your model. The Stamp tool (
) and the Drape Tool (
) can help add those entities and incorporate them into the terrain you’ve added.
Stamping
The Stamp tool creates a flat surface on terrain that matches the bottom of an entity you would like to place on your terrain. The Stamp tool creates the surface then seamlessly transitions the new object into the surrounding terrain.
To use the Stamp tool follow these steps:
- Move the entity you want to place on the terrain to just above the desired location on the TIN.
- Activate the Stamp tool.
- Click the entity you want to place.
- Enter an offset value in the Measurement box designating the space needed for the transition between the group and selected entity. The value should represent how the entity will blend in with the surrounding terrain and how flat or sloped that terrain is.
- Click the terrain. The pad for the entity will appear and the cursor will change to an arrow.
- Move the cursor up or down to set the flat surface’s height.
- Click again to complete the operation.
Draping
The Drape tool transfers edges from a flat face onto the curved surface of a TIN.
When you are ready to drape edges, follow these steps:
- Place the edges above the TIN.
- Select the edges you want to drape over the TIN.
- Activate the Drape tool.
- Click the TIN. The selected edges are now transferred to the TIN.
