Creating a Scaled Drawing
Within a group, you can apply a scale to a 2D drawing so that all geometry in that group reflects the selected scale. This geometry includes all native LayOut entity types. However, when you apply this scale, group entities such as text, labels, and dimensions retain their original properties, such as line and font size.
As a result, you can draw to scale and adjust that scale in LayOut without having to do a lot of mental math.
The following sections explain how to create and edit a scaled drawing. You also find tips for using the scaled drawing feature with SketchUp viewports and imported CAD files.
Table of Contents
Creating a scaled drawing
In a LayOut, a scaled drawing must be in a group. You can create a group for a scaled drawing in two ways:
- Create the group first and then start drawing.
- Start drawing and create a group from selected entities.
To begin with a scaled drawing group, follow these steps:
- Select Window > Scaled Drawing.
- In the Scaled Drawing panel that appears, click Make Scaled Drawing.
- Choose a scale.
- (Optional) From the Length drop-down list, choose Decimal, Architectural, Engineering, or Fractional. Depending on your selection, you might be able to choose a unit, such as meters or feet.
- Using the drawing tools, begin creating your drawing, and LayOut applies the scale you selected, as shown in the following figure.
- When you’re done, double-click with the Select tool anywhere in the drawing area that’s outside the scaled drawing context. Or press the Esc key.
![To create a scaled drawing from scratch in LayOut, use the Scaled Drawing panel](/sites/help.sketchup.com/files/images/lo-3000356-create-scaled-drawing.png)
If you’ve already started a drawing and want to turn what you’ve drawn into a scaled drawing, follow these steps:
- Select the entities that belong in the scaled drawing.
- Context-click the selection and select Make Group from the submenu that appears.
- Context-click the new group, choose Scale, and then select a scale from the submenu that appears, as shown in the following figure.
![In LayOut create a scaled drawing from existing geometry.](/sites/help.sketchup.com/files/images/lo-3000356-scale-group.png)
Editing a scaled drawing
To edit the entities in a scaled drawing, you simply need to open the group’s context. (See Grouping Entities for details.)
You can also change the scale by selecting the scaled drawing’s group entity and then selecting options from the Scaled Drawing panel.
Working with SketchUp viewports and CAD files
A SketchUp viewport can't be in a scaled group. If you want to use the scaled drawing feature to draw over a SketchUp viewport, you need to lock the viewport on a separate layer. Then, on a new layer over the viewport, you can create a scaled drawing.
If you import a CAD file into LayOut, you might be able to adjust the scale of your imported data to fit your LayOut document. Remember that the dotted line around a group indicates a scaled drawing, and you can see the current scale when the scaled drawing group is selected, as shown in the following figure.
![In LayOut create a scaled drawing from existing geometry.](/sites/help.sketchup.com/files/images/lo-3000356-scaled-CAD-import.png)
