The Measurements Box appears in the lower right corner of the SketchUp interface. The way the Measurements Box works changes based on which tool you are using:
  • When you create geometry, you can enter a value in the box and specify precise dimensions.
  • When moving or rotating, you can enter a value to help you position your geometry.
  • When scaling geometry, entering a value helps you scale to a precise value.
For any tool, you can change the type of unit of measurement by specifying the new unit type when typing in a value.
UnitHow to Specify ItExample
Inchesnumber + “10”
Feetnumber + ’10’
Millimetersnumber + mm10mm
Centimetersnumber + cm10cm
Metersnumber + m10m
The Flip and Move tools can help you create multiple copies of an entity in a pattern, also known as an array. You can use the Measurements Box to specify how that array appears.
Array TypeHow to Specify ItExampleSpacing
Externalnumber + x3xEqual distance as original and initial copy
Externalnumber + *3*Equal distance as original and initial copy
Internalnumber + /3/Equal distance between original and initial copy
