Using shortcuts is a great way to model efficiently, and SketchUp’s default shortcuts can help you get started.
If you want to create or edit your own custom shortcuts, see Creating and Editing Shortcuts. If you are on Windows, you can even export your custom shortcuts and import them later, or even share them with others.
| Tool | Shortcut | Icon | Learn More |
| Select | Spacebar | Selecting Geometry | |
| Lasso Select | Shift + Spacebar | ||
| Paint Bucket | B | Materials, Textures, and Environments | |
| Eraser | E | Erasing and Undoing | |
| Line | L | Drawing Basics and Concepts | |
| Rectangle | R | Drawing Basic Shapes | |
| Circle | C | ||
| 2 Point Arc | A | Drawing Arcs | |
| Move | M | Moving Entities Around | |
| Push/Pull | P | Pushing and Pulling Shapes into 3D | |
| Rotate | Q | Flipping, Mirroring, Rotating, and Arrays | |
| Scale | S | Scaling Your Model or Parts of Your Model | |
| Offset | F | Offsetting a Line from Existing Geometry | |
| Tape Measure | T | Precise Modeling with Measurements | |
| Orbit | O, Click+Drag | Viewing a Model | |
| Pan | H, Shift+Click+Drag | ||
| Zoom | Z, Scroll Wheel | ||
| Zoom Extents | Shift + Z | ||
| Make Component | G | N/A | Components |
| Image Igloo | I | N/A | Photo Matching |
| Back Edges | K | N/A | Drawing Basics and Concepts |
| Search | Shift + S | N/A | Searching in SketchUp |
