Components in SketchUp turn geometry in a model into reusable entities. For example, most buildings have at least one door and window. Instead of modeling these common objects, you can insert a component that you have already made, or even one made by someone else.
Like all geometry in SketchUp, a component is still made of edges and faces. The edges and faces are part of a special component group.
Check out the following articles for more information:
- Inserting Components - Learn the different methods you can use to insert components.
- Replacing Components - Replace one component with another component.
- Organizing Component Collections - Use collections to organize components for use in multiple projects.
- Interacting with Dynamic Components - Learn how to use and interact with dynamic components.
- Adjusting a Components Insertion Point - Identify and reset a components axis origin to help you insert a component with precision.
- Gathering Intelligence About Components - Learn how to locate and identify the background information for your components.
