At the bottom of the Main Toolbar, click to open the Expanded Toolset. The Expanded Toolset contains all the tools not seen on the Main Toolbar.
When you use a tool from the Expanded Toolset, that tool appears in one of the slots at the bottom of the Main Toolbar. You can customize the Main Toolbar to add additional slots.
The Expanded Toolset contains the following tools:
Icon Tool Name Shortcut Learn More Lasso Shift-Space Selecting Geometry Sample Material Applying Colors, Photos, Materials, and Textures Circle C Drawing Basic Shapes 2-Point Arc A Drawing Arcs Arc Drawing Arcs Polygon Drawing Basic Shapes 3-Point Arc Drawing Arcs Pie Drawing Arcs Freehand Drawing Freehand Shapes Rotated Rectangle Drawing Basic Shapes 3D Text Adding Text, Labels, and Dimensions to a Model Offset F Offsetting a Line from Existing Geometry Follow Me Extruding with Follow Me Flip Flipping, Mirroring, Rotating and Arrays Outer Shell Modeling Complex 3D Shapes with the Solid Tools Intersect Solid Modeling Complex 3D Shapes with the Solid Tools Union Solid Modeling Complex 3D Shapes with the Solid Tools Subtract Solid Modeling Complex 3D Shapes with the Solid Tools Trim Solid Modeling Complex 3D Shapes with the Solid Tools Split Solid Modeling Complex 3D Shapes with the Solid Tools Dimension Adding Text, Labels, and Dimensions to a Model Protractor Measuring Angles and Distances to Model Precisely Axes Adjusting the Drawing Axes Text Label Adding Text, Labels, and Dimensions to a Model Create Section Adding Text, Labels, and Dimensions to a Model Tag Controlling Visibility with Tags Zoom Z Viewing a Model Zoom Extents Ctrl/CMD+Shift+E Viewing a Model Zoom Window Shift + W Viewing a Model Position Camera Walking through a Model Look Around Walking through a Model Walk Walking through a Model AI Render SketchUp AI Render
Clicking Edit at the bottom of the Expanded Toolset allows you to customize your toolbars in the following ways:
Rearrange icons or move them between the two interfaces. Add tools to the Main Toolbar. Add or remove additional Recent Tool Slots. Add or remove separators.
