At the bottom of the Main Toolbar, click to open the Expanded Toolset. The Expanded Toolset contains all the tools not seen on the Main Toolbar.
When you use a tool from the Expanded Toolset, that tool appears in one of the slots at the bottom of the Main Toolbar. You can customize the Main Toolbar to add additional slots.
The Expanded Toolset contains the following tools:
IconTool NameShortcutLearn More
LassoShift-SpaceSelecting Geometry
Sample Material Applying Colors, Photos, Materials, and Textures
CircleC Drawing Basic Shapes
2-Point ArcA Drawing Arcs
Arc Drawing Arcs
Polygon Drawing Basic Shapes
3-Point Arc Drawing Arcs
Pie Drawing Arcs
Freehand Drawing Freehand Shapes
Rotated Rectangle Drawing Basic Shapes
3D Text Adding Text, Labels, and Dimensions to a Model
OffsetFOffsetting a Line from Existing Geometry
Follow Me Extruding with Follow Me
Flip Flipping, Mirroring, Rotating and Arrays
Outer Shell Modeling Complex 3D Shapes with the Solid Tools
Intersect Solid Modeling Complex 3D Shapes with the Solid Tools
Union Solid Modeling Complex 3D Shapes with the Solid Tools
Subtract Solid Modeling Complex 3D Shapes with the Solid Tools
Trim Solid Modeling Complex 3D Shapes with the Solid Tools
Split Solid Modeling Complex 3D Shapes with the Solid Tools
Dimension Adding Text, Labels, and Dimensions to a Model
Protractor Measuring Angles and Distances to Model Precisely
Axes Adjusting the Drawing Axes
Text Label Adding Text, Labels, and Dimensions to a Model
Create Section Adding Text, Labels, and Dimensions to a Model
Tag Controlling Visibility with Tags
ZoomZViewing a Model
Zoom ExtentsCtrl/CMD+Shift+E Viewing a Model
Zoom WindowShift + WViewing a Model
Position Camera Walking through a Model
Look Around Walking through a Model
Walk Walking through a Model
AI Render SketchUp AI Render
Clicking Edit at the bottom of the Expanded Toolset allows you to customize your toolbars in the following ways:
  • Rearrange icons or move them between the two interfaces.
  • Add tools to the Main Toolbar.
  • Add or remove additional Recent Tool Slots.
  • Add or remove separators.
