How to Use Add Location
SketchUp’s Add Location feature helps you capture and apply geolocation data and imagery to your model. To get started, open the Main Menu and click Add Location.
In the Geolocation Model window, narrow down the location where you want to place your model by typing in the box provided. You can type an address, part of an address, or a specific location name. Adjust the zoom level as needed using the controls in the upper right hand corner.
The red and green lines correspond to the red and green axes in your model. The orange arrow represents the True North. Adjust your model's relation to true north by clicking and dragging on the green or red axis lines.
After geolocating a model, you can add site context using map imagery. To define how you want to import site context, choose from the following options:
- Select an import type. Choose between a 2D plane or 3D mesh. When 3D mesh is selected, the slider can help you adjust the mesh density.
- Choose a map type. Choose between a basic street map and a satellite/aerial view.
- Choose an image provider. Choose between Bing or Digital Globe.
- Select a region. Adjust the size and position of the area you want to import, setting your site boundaries.
For more information, including detailed instructions for these features, see Geolocation and Terrain.
