Making Attribute Values End-User Configurable
You might want to allow the users of your dynamic component to configure some values of your dynamic component, such as the spacing between pickets in a fence or the width of your stairs. Values that are configurable will appear in a Component Options dialog box accessible from the component's context menu. To make a value configurable:
- Context-click on the component. The component's context menu is displayed.
- Select the Dynamic Components > Component Attributes menu item. The Component Attributes dialog box is displayed. Notice that the top-level component is listed.
- Click the + button next to the component's name. A list of attributes appears for the component.
- Click on the Details button to the right of the attribute you want to make end-user configurable. A drop-down list of display rules appears. There are two display rules allowing users to configure the attribute: 'Users can edit as textbox' and 'Users can select from a list.' This article explains how to configure the more complex display rule: 'Users can select from a list."
Select Users can select from a list. The Display label and a table appear. The following image shows the Display rule drop-down list, Display label field, and table.
- Type a label in the in the 'Display label' field. This field contains the user-friendly name you want to appear in the configuration box for this attribute.
- Click the add option icon in the List Option column of the table. A row is created with the field in the List Option column open for edit.
- Type
Small
in the 'List Option' field. This text will appear in a drop-down list in the Configure Options dialog box. - Press the Tab key.
- Type
1
in the 'Value' field. - Press the Tab key to accept the value.
- Repeat steps 7 through 11 using the option and value pairs of:
- Medium , 2
- Large , 3
Extra Large , 4
- Click on the Apply button. The attribute details panel closes.
- Click on the Close button. The Component Attributes dialog box closes. The user of this component can now configure the component's Slat Spacing attribute using the Configure Options dialog box.
