Uninstalling SketchUp
Windows
- Quit all open instances of SketchUp.
- Click the Start menu.
- Click Settings or search for Apps using the search bar.
- Locate SketchUp from the list of installed apps
- Click the context menu (...) and select Uninstall.
Tip: If you are having problems with SketchUp, try the Modify option, which verifies the current installation and will repair any errors in the current installation.
Mac OS X
- Open a Finder window.
- Delete the SketchUp folder from the main library:
- In the left pane of the Finder window, click Macintosh HD.
- In the right pane, click Library, and then Application Support.
- In the Application Support folder, find the SketchUp folder, and then drag it to the trash.
- Delete the SketchUp folder from your user library:
- In the left pane of the Finder window, click your user name, then click Library* in the right pane.
On Mac OS X 10.7 or newer, hold down the Option (Alt) button on your keyboard, click Go in the menu bar while the Finder is open, then select the Library option in the drop-down list. - Open the Application Support folder.
- In the Application Support folder, find the SketchUp folder and drag it to the trash.
- Delete the SketchUp application:
- In the left pane of the Finder window, click Applications.
- In the right pane, find the SketchUp folder and drag it to the trash.
- Delete the .plist file:
- In the left pane of the Finder window, click your user name.
- In the right pane, click Library*, and then Preferences.
On Mac OS X 10.7 or newer, hold down the Option (Alt) button on your keyboard, click Go in the menu bar, then select the Library option in the drop-down list. - In the Preferences folder, drag any of the following files to the trash:
- com.sketchup.SketchUp.<year>.plist
- com.sketchup.LayOut.<year>.plist
- com.sketchup.StyleBuilder.<year>.plist
- Empty the trash.
