Tags Panel and Tool
The Tags panel lists and helps you manage all the tags associated with your model. In the tags panel you'll find the following options:
Tags Panel
Tag Tool
The Tag tool ()in SketchUp for iPad has 3 optional tool modes:
- Sample () - Allows you to sample a tag assigned to another entity, changing your selected tag to the sampled one. Once you've sampled a tag, the Tag tool reverts to normal mode.
- Replace Matching () - Using this tool mode replaces the tag assigned to an entity, and all other entities it shares a tag with, with the selected tag.
- Tag All Instances () - Applies the selected tag to an entity and any copies of that entity.
The Tag tool works with all available iPad input methods. For more information on how to use tags in your model, see Controlling Visibility with Tags.
