Handling Error Messages
Error messages aren't fun for anyone. We've brought together a list of errors you may encounter if something goes wrong while using SketchUp and what to do to get things back to normal:
- Authentication Error
- File Currently locked by another user
- Unexpected file format or File not found
- Invalid filename
- .NET Framework is missing
- Unable to copy the license file
- Login errors
- Please enter an integer between 1 and 99
- This file was created in a newer version of SketchUp
- Your hardware configuration does not meet minimum specifications needed to run the application. The application must close. Error code: 6
If you don't see your error message covered here or are still having trouble, reach out to our Support Team.
