The Materials panel provides options to help you find and organize materials.
The drop-down menu on the Select tab (Texture Palettes on MacOS) contains a variety of default materials. To help you find the type of material that best fits your design, these materials are grouped into collections. All default materials are capable of using photoreal texture maps.
If you want to see materials used in your current model, select In Model from the list or click Home (
You can create a collection for a specific project, custom materials that you create, a specific color scheme, themes, and more. On the Select tab, click the Details arrow (
To add a frequently used collection to your favorites, go to the Select tab, click Details (
You can also remove materials from your model or from a collection. Removing unused materials can help improve performance. To remove materials:
- One Material – Context click the material you wish to remove and select Delete.
- Unused Materials – Select In Model from the list of collections and click Details (
). From the available options select Purge Unused. - All Materials – Select In Model from the list of collections and click Details (
). From the available options select Delete All.
