The default toolbar contains the most often used tools. To help you understand what tools are available and how to use them, take a look at the following table:
ToolNameWhat You Can Do with ItFind Out More
SelectSelect entities onscreen.Selecting Things
LineDraw straight lines.Drawing Lines and Shapes
FreehandDraw lines and curves freehand.Drawing Lines and Shapes
ArcDraw an arc based on an angle.Drawing Lines and Shapes
2 Point ArcDraw arc endpoints and drag the arc's bulge.Drawing Lines and Shapes
3 Point ArcDraw an arc from a pivot point.Drawing Lines and Shapes
PieCreate a closed arc, like a slice of pie.Drawing Lines and Shapes
RectangleDraw a basic rectangle.Drawing Lines and Shapes
Rounded RectangleCreate a rectangle with rounded corners.Drawing Lines and Shapes
LozengeCreate a rectangle with extremely rounded corners.Drawing Lines and Shapes
Bulged RectangleDraw a rectangle with two sides that bulge out.Drawing Lines and Shapes
CircleDraw a circle.Drawing Lines and Shapes
EllipseDraw an ellipse.Drawing Lines and Shapes
PolygonCreate a polygon with a specific number of sides.Drawing Lines and Shapes
TextAdd text in a bounded or unbounded text box.Adding Text, Labels, and Dimensions
LabelLabel specific items in your document.Adding Text, Labels, and Dimensions
Linear DimensionMark a straight dimension in the units you specify.Adding Text, Labels, and Dimensions
Angular DimensionMark the size of an angle.Adding Text, Labels, and Dimensions
EraseErase an element onscreen.Copying, Pasting, Erasing, and Other Editing Tasks
StyleSample an element's fill and stroke settings and apply them to other elements.Applying Styles
SplitSplit lines or shapes.Splitting and Joining Shapes
JoinJoin overlapping shapes.Splitting and Joining Shapes
Start PresentationSwitch to the full-screen presentation mode.Presenting Your LayOut Project
Add PageAdd a page to your LayOut document.Managing and Navigating Pages
Next PageMove to the next page.Managing and Navigating Pages
Previous PageMove to the previous page.Managing and Navigating Pages
