Delete all guides from the upload file. The fastest way to do so is to click Edit > Delete Guides.
Guidelines can clutter up the component especially when multiple components are placed around a design.
Tip: If you have placed guide points in your model for alignment targets, this method will delete them also. In this case you will need to use the Erase tool and individually erase all guidelines, leaving your guide points.
