SketchUp Pro 2024.0.2
24.0.594 Win 64-bit
24.0.598 Mac 64-bit
SketchUp Release Notes
Graphics
  • Fixed an issue where certain large models would not render properly when Multi-sample Anti-aliasing is set to 2x/4x on some Mac Laptops.
Live Components
  • Improved management for Live Component materials in SketchUp. When a material is changed in a Live Component, SketchUp now applies the new material to the user selected material. Only the user selected and applied material shows in the materials panel.
Extensibility
  • Fixed reported security issues in the SketchUp SDK (SketchUp and LayOut C APIs).
  • Updated OpenSSL to version 3.2.2. Extension developers using any functionality relying on OpenSSL should test that their extensions function as expected.
  • Fixed C API overlay crashes on Macs with Intel CPUs.
  • C API overlay artifacts no longer occur when the SketchUp window was resized.
  • The Ruby and C API documentation has been updated.
  • Fixed an issue where http/https requests could hang when using UI::HtmlDialog.
  • Fixed an issue where http/https requests could fail to send their body in some scenarios when using UI::HtmlDialog.
Stability
  • Fixed a miscellaneous crash at shutdown.
  • Fixed a miscellaneous crash affecting Real Time Viewing.
Security
Miscellaneous
  • Fixed an issue where the sizing cursor would get stuck between dialog panels when dropping the sizing cursor from one panel onto another panel.
  • Fixed an issue where it was not possible to reset group axes or infer to them, if “hide rest of model” is enabled.
  • (Mac) Fixed an issue where Scenes did not display properly in the panel.
Known issues
The following are known issues that will ship in 2024.0.2 and will be addressed in a future release:
  • High DPI scaling issues and Multi-monitor issues will still persist.
LayOut Release Notes
Stability
  • Switching to a scene without a style tracking enabled and without a cached style object will no longer crash LayOut.
  • (Windows) Fixed a crash that could occur accessing a SketchUp model viewport containing a section plane.
SketchUp Model Viewports
  • Fixed an issue where viewports could shift in select instances when the scene was changed.
  • Fixed an issue which would cause disconnected linear dimensions to reconnect to new points in a SketchUp Model Viewport, causing a shift of the dimensions.
  • Fixed an issue where a Label position could shift when attached to an image that has been resized.
