SketchUp Desktop 2024.0.2
SketchUp Pro 2024.0.2
24.0.594 Win 64-bit
24.0.598 Mac 64-bit
SketchUp Release Notes
Graphics
- Fixed an issue where certain large models would not render properly when Multi-sample Anti-aliasing is set to 2x/4x on some Mac Laptops.
Live Components
- Improved management for Live Component materials in SketchUp. When a material is changed in a Live Component, SketchUp now applies the new material to the user selected material. Only the user selected and applied material shows in the materials panel.
Extensibility
- Fixed reported security issues in the SketchUp SDK (SketchUp and LayOut C APIs).
- Updated OpenSSL to version 3.2.2. Extension developers using any functionality relying on OpenSSL should test that their extensions function as expected.
- Fixed C API overlay crashes on Macs with Intel CPUs.
- C API overlay artifacts no longer occur when the SketchUp window was resized.
- The Ruby and C API documentation has been updated.
- Fixed an issue where http/https requests could hang when using UI::HtmlDialog.
- Fixed an issue where http/https requests could fail to send their body in some scenarios when using UI::HtmlDialog.
Stability
- Fixed a miscellaneous crash at shutdown.
- Fixed a miscellaneous crash affecting Real Time Viewing.
Security
- Multiple libraries were updated to their latest versions as part of a security patch to remediate identified vulnerabilities:
- zlib upgraded to 1.3 CVE https://nvd.nist.gov/vuln/detail/CVE-2023-45853
- libTIFF upgraded to 4.6.0 CVE https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2023-52355
- libJpegTurbo upgraded to 3.0.3 to address https://nvd.nist.gov/vuln/detail/CVE-2023-2804
- Ruby 3.2 patched with openssl to 3.2.2 and zlib to 1.3.1
Miscellaneous
- Fixed an issue where the sizing cursor would get stuck between dialog panels when dropping the sizing cursor from one panel onto another panel.
- Fixed an issue where it was not possible to reset group axes or infer to them, if “hide rest of model” is enabled.
- (Mac) Fixed an issue where Scenes did not display properly in the panel.
Known issues
The following are known issues that will ship in 2024.0.2 and will be addressed in a future release:
- High DPI scaling issues and Multi-monitor issues will still persist.
LayOut Release Notes
Stability
- Switching to a scene without a style tracking enabled and without a cached style object will no longer crash LayOut.
- (Windows) Fixed a crash that could occur accessing a SketchUp model viewport containing a section plane.
SketchUp Model Viewports
- Fixed an issue where viewports could shift in select instances when the scene was changed.
- Fixed an issue which would cause disconnected linear dimensions to reconnect to new points in a SketchUp Model Viewport, causing a shift of the dimensions.
- Fixed an issue where a Label position could shift when attached to an image that has been resized.
