Importing Files
Importing images and drawings into a SketchUp model is a great way to enhance it and give it that spark of life. SketchUp for iPad supports importing files created in the following formats:
- Image (.png, .jpg)
- SketchUp (.skp)
- Stereolithography (.stl)
- 3D AutoCAD Model (.dwg.dxf)
Follow these steps to import a file:
- Select Import (
) from the Main Toolbar at the top left of your screen. - In the file browser that appears, locate and choose the file you wish to import.
- Select the file. The imported file becomes an entity within your model.
Exporting Files
SketchUp for iPad supports the ability to export your model using the following formats:
- Image (.png)
- Animation (.mp4)
- Pixar USDZ File (.usdz)
- Object File (.obj)
- 3D AutoCAD Model or 2D AutoCAD Drawing (.dwg, .dxf)
- PDF (.pdf)
Use the following steps to export a file from either the Main Toolbar or the Scenes panel:
- Click or tap the Export (
) icon. The Export window will appear.
- Use the File Type dropdown menu to select the import format.
- Format specific options will appear. Make any additional changes as needed.
- Tap or click Export.
To export a file from the Home screen:
- Tap or click the Overflow (
) icon next to the model you want to export. - Select Export...
- Select the desired export format from the list.
Choose any format specific options and tap or click Export.
