SketchUp 2014 - Maintenance Release 1
Version Numbers:
Win: 14.1.1282
Mac: - 14.1.1283
SketchUp
General
  • Fixed the File > Generate Report functionality which was failing to generate a report.
    Note: if you are installing SketchUp 2014 M1 over a previous version of SketchUp 2014, you will need to go to the Extension Warehouse and update the Dynamic Components extension to receive this fix. If you are installing SketchUp 2014 M1 for the first time, no further action is needed.
  • Fixed a "Callback function" error that could occur when a single non-component (or non-group) entity was selected and Component Options dialog was opened.
  • Fixed the Component Browser search box to no longer show the text "Is:downloadable" when paging through search results.
  • Fixed an issue where shadows did not update properly when switching between scenes in models where scene transitions were turned off and the "Shadow setting" Property to Save was unchecked.
  • Changed the status bar text for the Paint tool to fix some text that was incorrect.
  • Windows: fixed an issue where the units displayed in the model were not always correct after changing them in Model Info > Units. This issue showed up when viewing the dimensions of materials and when selecting arc, curve and circle entities.
  • Mac: fixed an issue where Photo Texturing could fail after uploading a model to the 3d Warehouse.
    Note: if you are installing SketchUp 2014 M1 over a previous version of SketchUp 2014, you will need to go to the Extension Warehouse and update the Photo Textures extension to receive this fix. If you are installing SketchUp 2014 M1 for the first time, no further action is needed.
  • Mac: fixed an issue where dropdown toolbar icons could sometimes disappear, leaving only arrows.
  • Mac: updated the Advanced Camera Tools so that the + and - keys work again.
    Note: if you are installing SketchUp 2014 M1 over a previous version of SketchUp 2014, you will need to go to the Extension Warehouse and update the Advanced Camera Tool extension to receive this fix. If you are installing SketchUp 2014 M1 for the first time, no further action is needed.
Classifier
  • Added the ability to import classification systems that reference external files.
  • Fixed the filter box to accurately find Type information when searching on a keyword that matches the classification system name.
  • Added an error message when importing classification systems that have circular dependencies (which are currently not supported).
  • Fixed an issue where duplicate attributes could be seen when importing certain classification systems.
  • Relaxed the strict format requirements for the "created" and "modified" date fields in the documentProperties.xml file within the SKC format.
  • Windows: fixed a crash that could occur when doing a File > New after canceling a classification import.
  • Mac: fixed a crash that occurred when filtering on a keyword and toggling simplification in models with multiple classification systems.
  • Mac: fixed an issue where the IFC Options Cancel button didn't cancel changes made to the options.
Localization
  • Unicode languages: fixed a very common crash that could occur when saving some models with validity errors.
  • Made numerous fixes for incorrect translations.
Ruby - Please review our Ruby Release Notes here.
SDK
  • Mac: changed the deprecated SDK (SkpReader) to be able to read SketchUp 2014 files.
SketchUp Viewer
  • Mac: fixed an issue that caused SketchUp Viewer to crash when launching it on a machine where SketchUp was not installed.
LayOut
Bug Fixes:
  • Mac: Model surfaces containing "cut opening" components would sometimes disappear when vector or hybrid rendered, revealing linework that should have otherwise been hidden.
  • Mac: LayOut would freeze or crash during a vector or hybrid render of certain models and has been resolved.
  • Windows: The thumbnail list of pages in the Page Inspector was not properly refreshing when switching between 2 or more open documents. Upon switching to another open document, the Page Inspector would continue to show the previous document's thumbnails.
