SketchUp 2013 - Maintenance Release 2
Version Numbers:
Win 13.0.4812
Mac 13.0.4811
SketchUp:
The following issues have been fixed:
  • Graphics card-related crash when updating scenes which use a standard view (e.g., Top, Front) on some machines.
  • Mac: crash when exporting a model with dimensions or text to 2d DWG.
  • Mac: VCB does not work if you give it focus. Previously, when clicking in or tabbing to the VCB on the Mac and typing data, the VCB didn't behave as expected.
  • Mac: machines with a 10.8 operating system show instructor content that is Windows-specific.
  • Windows: crash when selecting the "File" menu item on a small subset of machines. Previously, on some machines, selecting the File menu item crashed SketchUp. This crash was caused by the fact that we used to load all exporters and importers when the File menu item was selected and, on some machines, loading the FBX exporter caused SketchUp to crash. Now, we only load exporters and importers when exporting or importing files. This should lessen the likelihood of experiencing the crash - i.e., the crash should occur now only when selecting File > Export > 2d graphic and File > Export > 3d graphic vs when selecting the File menu item. We are still working on fixing the FBX crash itself. The workaround to this crash is as follows:
    1. Open Windows Explorer
    2. Navigate to the C:\Program Files (x86)\SketchUp\SketchUp 2013\Exporters directory (or wherever you have installed SketchUp)
    3. Rename the file 'Skp2Fbx.dll' to some other name - e.g., Skp2Fbx.bak
    4. Launch SketchUp again - the crash should no longer occur
  • Windows: SketchUp loses floating toolbar visibility state when closing from a minimized state. Previously, floating Ruby toolbars would no longer be visible when re-launching SketchUp if SketchUp were closed from a minimized state via the Windows taskbar.
  • SketchUp quits extracting at first failure when extracting files from *.rbz zip files. Previously, when extracting *.rbz files, SketchUp would quit on first failure. Now, SketchUp continues to extract files if it encounters failures.
  • Clicking on the "Name" column header in the Layers dialog doesn't sort layers as expected.
  • Model Info > Geolocation Dialog does not always refresh after adding a location. Previously, after adding a location, the Model Info > Geolocation dialog did not always reflect that a location had been added.
  • Crash when clicking on a material or style on some Unicode configurations. SketchUp previously crashed when clicking on a material or style when it was run using a username containing Japanese/Chinese characters on a native operating system.
  • SketchUp fails to export and import for some Unicode configurations. SketchUp previously failed to import and export files when it was run using a username containing Japanese/Chinese characters on a native operating system.
  • Bad translations, missing translations and string truncations for the FIGS languages.
  • Crash when de-authorizing SU when using the Italian Windows build.
The following new things have been added:
  • We have new installs for the following languages - Japanese, Korean, Brazilian Portuguese, Simplified Chinese and Traditional Chinese.
LayOut:
  • Crash on startup, or shortly after initialization, on Windows machines with user account names that were composed of at least one special character. Typically, this was more present with localized builds.
